TechieAsh
03-15-2019 03:21 AM in
Hi All,
I'm using STANDARD Galaxy S10 for past one week and I feel like battery is not holding up. I have exynos variant as I'm from India.
1. I feel idle battery drain is way too high than it should be.
2. Screen on time is barely 3 hrs with battery usage of just 7-8 hrs.
3. Charging takes awfully long, somewhere between 2-2.5 hrs for 20% to 100%.
4. I have kept dark mode always on, AOD off, wqhd resolution, medium power saving with no background data restriction.
5. With constant wifi, I managed 4.5 hrs of SOT but with LTE, barely 2.5-3 hrs.
6. I feel like even when device doesn't need much power, the cpu is throttling at higher or max capacity causing this excessive drain.
Please let me know your experience, if u agree or disagree with me or feedbacks if any.
Note: I'm taking about standard S10, neither plus model nor the e variant.
4 Comments
abhaidwivedi
03-15-2019 03:44 AM in
kindly reset your phone once
hopefully ur problem will get resolved
Not applicable
03-15-2019 04:15 AM (Last edited 03-15-2019 04:15 AM ) in
yes. it drains in LTE. but from yesterday my phone with stand battery as of now the SOT is 8 hrs 22 mins. still 16% battery left. didn't change any settings. keep it in FHD only. it surely reaches 9 hours. g
for 3400 mah it's good.
Not applicable
03-15-2019 05:22 AM (Last edited 03-15-2019 05:23 AM ) in
SOT 9hrs 30 mins from 100 to 3%. it's good. I'll post if I get very low performance also if any.
sukruth29
03-15-2019 07:38 AM in
just reset and restart u r phone
and dont keep a whole night charging
