Battery drain issues feels on new S24 ultra
(Topic created on: 02-26-2024 05:18 PM)
muhammedsha
Hey there..
I have buy a new s24 ultra just 2 days before and i have feels like the battery was draining too faster... I'm getting only 6hrs screen time..
Anyone has facings the same issues..??
13 Comments
jawadcoral
Please check your battery usage and always check if any background apps are running.
Lots of battery optimizing available on internet.
VikrantTambade
Hi,
Note that since it is just 2 days old phone, it's battery optimization algorithm will take time to understand your usage pattern and then it will start optimising.
muhammedsha
How long it will take.. any idea..??
VikrantTambade
Around 10 days....
MOQBALI
It depends on your use of the phone and adjustment of some settings, such as screen brightness, screen resolution, and putting some programs on sleep.
Cuckud
Approximately 7 to 10 days. If you see the battery option in the settings, it will say learning usage patterns but once it is completed, that line disappears and battery performance is noticeably much better. What I dislike is the standby battery drain time despite having the AOD off.
muhammedsha
After 3 days the learning pattern has disabled and now it's showing the battery performance ..
Now it shows that the full charges least 12hrs..🥲
Cuckud
It will get better after few more days and will show a day on the usage.
muhammedsha
Thank you 😊
