Battery drain issue
(Topic created on: 3 weeks ago)
man384
anyone else having battery drain issues after the latest update? 😫 My S24 Plus has been struggling to hold a charge all day. Hoping it's just a bug that will get ironed out soon! Anyone else experiencing this? Let me know your battery life in the comments. #S24Plus #BatteryDrain #UpdateProblems
3 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
