Battery drain issue
(Topic created on: 03-24-2023 12:31 PM)
PRASANNA007
2days ago i had purchased s21fe it have battery drain issue overall screen time 3.30hrs only this is running with android 13 one ui 5.1
3 Comments
Akshvani
Check all unnecessary access permission make them off, i had same issue it solved to certian level.
Akshvani
Also try clear catche from recovery mode, it makes phone very smooth. I got this suggestion from this forum and trust me it's worked weel even there is little improvement in battery drainage issue
cs-member11
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
