Battery drain issue in s24
(Topic created on: Thursday)
Dravid1
In s24 during idle state battery draining is more, in 8 hours it is down by around 20 percent, mobile data, wifi, location everything is turned off and recent apps are cleared still it's draining.
If we have 21 or 22 percent during night in morning it will switch off.
When I turn battery saver also it is not helping.
Anybody facing issues like this???
5 Comments
Jith__
🔋 Top Solutions for Battery Drain on Galaxy S24
1. Check Battery Usage
Go to: Settings > Battery > Battery Usage
Identify apps consuming unusual power.
🔧 Fix: Force stop or uninstall those apps.
2. Turn Off Background Apps
Go to: Settings > Apps > [Select app] > Battery
Set to “Restricted” for non-essential apps.
3. Enable Battery Saver Mode
Swipe down quick panel > Tap Battery Saver
OR go to: Settings > Battery > Power saving mode
4. Disable Always-On Display
Go to: Settings > Lock Screen > Turn off Always On Display
5. Limit Location Services
Go to: Settings > Location > Turn off when not needed
Or set to “While using the app”
6. Screen Brightness & Refresh Rate
Reduce Brightness: Avoid using Auto Brightness in bright daylight
Reduce Refresh Rate:
Settings > Display > Motion smoothness > Set to Standard (60Hz)
7. Update Software
Go to: Settings > Software update > Download and install
📌 Samsung releases battery optimization patches frequently.
8. Clear System Cache
Power off the phone
Hold Power + Volume Up until Samsung logo
Use volume keys to select Wipe Cache Partition > Confirm with Power button
9. Disable 5G (if not needed)
Settings > Connections > Mobile networks > Network mode > Select LTE/3G/2G (Auto)
10. Use Sleep & Deep Sleep Mode for Apps
Settings > Battery and device care > Battery > Background usage limits
Add unused apps to Sleep or Deep sleep
BiRdMaN
Send an error report along with log files to customer support through this members app and Samsung will fix it in the next update. To do that follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
All these issues are coming after updating to ONE UI 7
If you find this helpful I'd appreciate it if you could Accept it as a solution Thank you 😊
goodthings
goodthings
You're welcome to here.
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
