Battery drain and device heating while using YouTube
(Topic created on: 01-08-2021 08:51 AM)
AntonyK09
Is anyone facing battery drain and overheating problems while using YouTube? If there is a solution to fixing the above problem, please do help me out! I'm using the S20+ 5G.
12 Comments
Alphazor007
Do you face this problem only with youtube?
AntonyK09
Yes and sometimes Device care also eats up a lot of battery (about 20% or more everyday)
Alphazor007
Can you send me a screen shot of your battery usage.
AntonyK09
I've sent it to you privately as I can't send screenshots here.
AntonyK09
and one of the screenshots is there in my previous post
Alphazor007
okay.. thanks . Have you tried reinstalling the app? Or clear data and try again
AntonyK09
I've uninstalled the updates for YouTube very recently and reinstalled them and the problems still persists.I clear the cache for the app everyday.
Try booting in safe mode and see if it still heats than there is a problem to your device
AntonyK09
It heats up only when I use YouTube and the battery drains a lot for some reason because of Device care.
