Battery drain after updating to one UI 6
(Topic created on: 12-21-2023 02:42 PM)
Sdrocks002
Does anyone face any battery drain faster using 5g updating to one UI 6
6 Comments
Md-Mahfuj
After the update, my phone is charging fine.
AJAB_MORIA
Sir ! Please wait for Next Update.
Aditya_Raj108
After one UI 6.1 update your battery life will be fixed with AI Features.
Sdrocks002
Ok thanks
Aditya_Raj108
You're welcome.
cs_member10
Dear Samsung Member,
As per your concern, we would request you to kindly perform the following steps by a given link to resolve your issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can check the device in safe mode and for the same mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
In case the issue persists, kindly share the report of the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
