Battery drain after one ui7
(Topic created on: 05-05-2025 01:42 PM)
wego9
S23 ultra before update to one ui7 battery was stable now i charge my phone 2 3 times per a day
Solve it quickly Samsung
8 Comments
eieiej
Beginner Level 3
انا كذلك
wego9
خربولنا الهواتف بالتحديث
Face7
Try to put your phone on 4g network coz it works with me .. mine is s25 plus
Mueen_1991
I do but still problem., battery in one ui 6 was better
Face7
Check the background apps that are working .. put unused apps to deep sleep
Mueen_1991
I do all of that still problem
Face7
Now I noticed ur phone is s23 .. so either you get a new one or change your battery and hopefully your problem will be solved
جام
البطارية صارت سيئة بعد التحديث
