Battery drain after Feb security patch
(Topic created on: 03-03-2025 01:55 PM)
ph0enixs
I don't know what they dropped in this Feb security patch but my s24 ultra is running hot throughout the day and i am getting truly abysmal battery projections and even worse sot
I was getting 6 hrs of sot before the February security patch
Before the update
3 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
