Battery consumption
(Topic created on: 07-05-2024 12:05 AM)
Ananthuo
Contact storage  consuming battery  daily 8 to 10 % of my  battery any solutions
12 Comments
Ananthuo
Hi bro, battery drain overnight up to 8% is normal, bro. For background processing, app notifications, and network strength-based usage will be there. Some days it will be reduced to around 5%. We can use this battery graph reading method to understand whether any problem is present or not.
Ananthuo
It's not overnight it's just a application using that much of battery
Troubleshooting Contact Storage Battery Consumption
Solutions
• To reduce battery consumption caused by contact storage, check sync settings, update apps, clear cache and data of the Contacts app, disable unnecessary background activity, check for background apps, and consider a factory reset as a last resort.
Backup Contacts
• Ensure your contacts are backed up before clearing data or performing a factory reset.
Contact Samsung Support
• If the issue persists, contact Samsung support or visit a service center.
Ananthuo
Ok. I just bought the phone just a week
Try to make adjustments after adjustments, but if it doesn't work and the phone is new I suggest going to Samsung to examine the problem maybe there is a manufacturing defect.
Ananthuo
Thanks
GalaxyNerd
I think it Could be syncing issue your device is trying constantly to sync contacts from cloud from google accoint or Samsung account i am not sure
First long press on contacts icon>app info>clear storage data then Just try to sign out from both accounts then login again
Ananthuo
No I turned off back up still no change
