Battery concern
(Topic created on: 3 weeks ago)
regalm
I would like to know if this is normal on my s24 ultra, at first it said that a full charge would last 1d and 15h and now it is estimating that a full charge will last 1d . This is making me scared.
3 Comments
Tendai777
The battery usage estimates are based on your personal usage patterns. If you give the phone to someone else, the battery usage statistics will likely differ.
Futes
My battery doesn't last me a day, right after disconnecting from a charger, boom it's start decreasing the battery power
Pierre44mp
It has a,lot to do with how many apps you download that runs in background and unofficial apps and custom widgets takes up a lot of background usage. You also need to be selective which apps you give location permissions,only if apps can't run without it,tiktok on location for instance is questionable, or samsung music. Put other apps to sleep mode if not used often. If you are on wifi mostly ,you will save a lot more battery ,if you have spotty internet connection, you will feel the phone heating up a bit and using more battery. Try disable 5g ,because it's only supported in few regions,and do that for both Sims,or set up a routine to only let it work in certain regions where you know there is coverage to let the receiver not keep on searching for non existing signals. Also activate low power usage and don't use full brightness on screen,and de activate Aod. With these tips,you will see your usage go down significantly! Remember each app you install gets permissions like location,be selective on that whenever you install a,new app ,or delete and re install an app.
