Battery charging speed is slow
(Topic created on: 06-11-2024 03:24 AM)
97kmr
After last update for s24 ultra my phone charging speed is very slow. Iam using samsung 45w charger
4 Comments
itsyoungboy
Check the setting if fast charging is disabled
My mom has fast charging by default but it doesn't seem to be charging fast.
(Members reply only)
Known bug, 33 W still works if turned off
Samsung_specialist
Before you try the recommendations below, be sure to check if your device's software and related apps are updated to the latest version. To update your mobile device's software, follow these steps:
Step 1. Go to Settings > Software update.
Step 2. Tap on Download and install.
Step 3. Follow the on-screen instructions.
Check 1. Check your charger or charging cable
Check 2. Remove foreign debris from the charging port
Check 3. Fast charging option
Check 4. Moisture detected error notification https://www.samsung.com/ae/support/mobile-devices/issues-with-wired-charging/
