Mahendra14
Battery charging has become slow after One Ui 3 update for galaxy S10 lite. If any one of you guys have updated your s10 lite to latest update, please check and confirm. Usually it takes less than one hour to full charge. Now I felt it takes 90 min to get full charge. Requesting you guys to check and update me. Thank you.
6 Comments
lakshyagrover1997
samsung might have slowed the charging speed to protect battery from degrading very quckly
PankajS10Lite
should I update my s10 lite to 3Ui or not?
lakshyagrover1997
update it but reset the cache or if you can hard reset after updating
cs-member13
Dear Samsung Member,
We are sorry for the inconvenience caused to you. We request you to kindly send us the error log file along with the Video or Screen-shots within 15 minutes of issue occurrence through error report section from Samsung Member Application:- Samsung member > Click on beta banner > Switch to beta mode > Beta feedback > Send feedback > Error report. As this will help us to further investigate and resolve your concern.
Mahendra14
Thank you. sure will do that.
PPuneet
Beginner Level 3
I m facing the same issue. battery takes 2hrs time to charge 10 to 100%..
