Battery charger restricted to 15w in oneui 6.1 update
(Topic created on: 03-29-2024 12:12 AM)
Pruone
Attention People using fast charger for s23 ultra, now the charging speed is limited to 15w, even if u have 25w brick..
16 Comments
iceuniverse2
App name?
Pruone
Electron
igan
whats the name of this app ?
Pruone
Electron
I have S23 and charge it with 25W Samsung charger. It took same time ~ 75 mins as it was prior to upgrade.
juggaloscrub
There's ur problem right there.  U need to be using the 45w
Why I should use 45W charger IF my phone doesn't support it OR I don’t need it.
33 Wh maximum and only works when turned off. In turned on mode it only does 14 wh as said. Assuming it uses power bank it can do 17W. But usually it can't.
BasilJJ
Watts go up and down before the update too so I think thats normal
