03-13-2020 02:56 PM (Last edited 03-13-2020 03:01 PM ) in
Galaxy SSolved! Go to Solution.
03-13-2020 05:40 PM in
Galaxy Sif you use your device heavily for a day, then it will show reduced battery expected life for few days.
but, if you use it lightly for few days after a heavy use, it will again show that expected life is 2d 6hrs.
so don't worry about that expectation...
03-13-2020 02:59 PM in
Galaxy S- Mark as New
03-13-2020 03:04 PM in
Galaxy SBut I will check uninstalling other banking related apps.
Thank you.
03-13-2020 03:10 PM in
03-13-2020 03:12 PM (Last edited 03-13-2020 03:14 PM ) in
Galaxy SI hope that other users with 'Galaxy S10 lite' share their views or findings if they are facing the same issue like mine.
03-13-2020 03:17 PM in
03-13-2020 06:24 PM (Last edited 03-13-2020 06:25 PM ) in
Galaxy SWhat I am trying to say is that till today I was getting estimated 54 hours of battery capacity at full charge of 100% with medium power saving mode enabled and today it fell down to 42 hours of battery capacity at full charge of 100% with medium power saving mode enabled and nothing has been changed in system, apps or my usage pattern, everything is same as before but battery capacity has reduced to 42 hours from 54 hours which is loss of 12 hours (a half day) worth of battery capacity that seems very unusual, I could understand if the capacity drop would have been of 4-6 hours but 12 hours of drop in a day is confusing.
Thank you for the reply.
03-13-2020 10:15 PM in
03-13-2020 10:51 PM (Last edited 03-13-2020 10:51 PM ) in
Galaxy SHumanly not possible to use the mobile same hrs every day. Your screenshot of last 7 days may help to predict and understand that number better
