Battery and Alingment issue in Lock Screen
(Topic created on: Friday)
sir100
After one UI 7 update the s23 phones battery **bleep**....now one UI 8 forcing us to charge the phone 3 to 4 times a day....very pathetic from samsung....pls look into the battery performance...even my friends bought s25 ultra and it also having same battery prblm....
One more problem arised in lock screen while charging or getting new notification alerts the animations alignment still causes problm...
Bugs not fixed....
2 Comments
sir100
Thanks for ur useless suggestion....👏👏.waited for many updates bt nothing changes...also error reported many times before in samsng apps
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select "try another way" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists and regarding alignment issue, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
