Battery alarming on s24 ultra
(Topic created on: 12-06-2024 02:40 AM)
hamzaa9
Guys I feel like this battery performance isn't ideal. 80 percent battery gone even though I don't use it that much. S24 ultra ki battery is supposed to be good. I never had this battery performance on iphone 14 pro but idk what's happening here. Any suggestions? Please help 🙏
3 Comments
Check out your Device Performance Profile. Also, does this happen on idle? Or during prolonged use. And do check your bagtery health percentage since battery degradation is the biggest culprit in such situations.
hamzaa9
Yes bro it happens on idle literally. Last time it battery dropped like 30 percent when I was sleeping last night. Idk what is happening
One thing i should mention is that to keep the "Device Sync" feature turned off, i kept it off on my S8 all the way to my S22. Sync drains battery juice a lot actually.
