Resolved! Solved
Battery S20 plus
(Topic created on: 01-01-2021 02:57 PM)
DeepakBindra
Hi everyone Happy new year. Please see the pic I am not able to see the battery usage by Apps. Kindly suggest
Prateekaggl
The fix has been posted on YouTube. Full charge the phone then while on charging clear the data for Device care app and Samsung Device health service app, then unplug and start using the phone. After sometime it will start showing usage data.
17 Comments
DeepakBindra
Thanks
it's Bcoz OneUI 3.0 Have Some Small Bugs
DeepakBindra
Yeah it all started today. Till yesterday it was fine
Amul0509
same issue since 30.12.20 S10 Lite
samfan156
this is a bug
send feedback to Samsung by using get help section
GetHelp>>SendFeedback>>ErrorReport/AskQuestion>choose appropriate section
DeepakBindra
already did
Shivaraman
i have the same problem
Prateekaggl
yes, i tested on my s20+ and s10 lite
