04-29-2025 11:08 AM in
Galaxy S- Mark as New
04-29-2025 11:13 AM in
04-29-2025 11:14 AM in
04-29-2025 11:15 AM in
04-29-2025 04:16 PM in
04-29-2025 04:39 PM in
Galaxy SDear Samsung Member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
1. Galaxy device slow charging issue: ● We always recommend to use genuine Samsung charger for charging your device.
● Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc. If it is damaged, then kindly visit your nearest service center to get it replaced.
● Kindly check the charger functionality with a different device or try to charge the same device with a different charger.
● Check charging: If rating is 15W or above: Kindly try to charge the device in a non-inverter socket.
● If you using normal socket: As a safety measure Fast charging may not support, while you are using the device hence, request you to keep the device idle and check the charging performance.
Note: Kindly open Device care from settings > Battery > Please tap on three dots (more option) at the top right hand side > please select settings > enable fast cable charging.
For Android 11: Kindly open Device care from settings > tap on Battery > tap on More battery settings > Fast charging > Turn on.
● Kindly follow the standard charging procedure. i.e. please charge the device in switched-off condition for 10 minutes.
2. Galaxy device battery drain issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
9. Reset the device:
IMPORTANT:
• For this:
