Resolved! Solved
Battery Health Status Issue
(Topic created on: 03-25-2025 01:08 PM)
daliaalb52
Why my brand new S 20 plus shows battery life normal instead of good
When I checked *#9900#* dumpfile
It says my mSavedBatteryAsoc is 90
While it's my 6 day of using it !
What shall I do ? Return it ? Or just a technological misinterpretation that can be fixed ?
I need reply urgently . Thanks😊
Harsha-D
Normally In the first 14 days, your device learns your usage pattern and will then adjust your battery's performance accordingly.
7 Comments
Harsha-D
it will take time to catch your normal routine
daliaalb52
Like how much time?
Harsha-D
Harsha-D
Hope u got the info.
Please click on the 3 dots and select "accept solution" if my reply helps you..
daliaalb52
Thank you very much
GalaxyNerd
Definitely refurbished phone bro new body with old battery there's no new s20 now available it's 5 years old model
If you want to check when it was first activated you can download app called phone info it will show you manufacturing date
Download app and install it then enter serial number
https://www.apkmirror.com/apk/vndnguyen/phone-info-%e2%98%85samsung%e2%98%85/phone-info-%e2%98%85sam...
Samsung_specialist
We’re sorry to hear that you’re experiencing an issue. Please check your battery by following these steps:
1. Open the Samsung Members App and tap "Support" at the bottom.
2. Check your battery status through "Phone Diagnostics."
3. Tap "Test" and follow the instructions.
Additionally, you can follow the steps in the link below to help extend your battery life.
https://www.samsung.com/ae/support/mobile-devices/the-battery-drains-fast-how-do-i-extend-the-batter...
