Battery Draining?
(Topic created on: 09-01-2018 03:11 PM)
AliTheMan
Hi,
Anyone experiencing battery draining since the last update? I even tried flashing to the UK BLU firmware and the issue was still there.
16 Comments
ArtGrapher
Yeah exactly , mine started from Oreo and it's getting more dreadful over and over
AliTheMan
Ughh....I guess it's an update problem. I've tried many different solutions and none has worked. What is your firmware region if you don't mind me asking? XSG UAE?
ArtGrapher
No not at all , True mine is UAE
gabul
new version S7
Subzero355
Don't blame it on the Update, it's just the Battery's aging.
AliTheMan
Trust me, I know when a battery is aging. My issue started immediately after the update. it doesn't make sense that the battery aged all of a sudden
Subzero355
performing a factory reset might refresh things up too, the battery starts to age just after 2 years of use, get used to it i guess. or if it's a software related problem, we might be lucky to get solution along with the next security patch, but first Samsung must know that we're facing this issue, so consider reporting it.
robA52017
I have reported it also. It's not normal and not old battery. It's something that changed overnight
AliTheMan
My phone is not even two years old yet. I did a factory reset and even flashed a different firmware, BLU UK and the problem is still there. Some people are saying that I need to wait a few days for the new update to "settle" down, but I don't know if a software needs to settle down lol I will wait few days and see what happens
