11-10-2020 01:33 AM in
Galaxy S- Mark as New
11-10-2020 07:41 AM in
Galaxy Shttps://r2.community.samsung.com/t5/Tech-Talk/Battery-saving-tips/td-p/2920797
11-10-2020 07:59 AM in
Galaxy SA. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
11-10-2020 08:00 AM in
Galaxy S1. Connection>more connections settings> disable nearby device settings.
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Google >click on 3dot at right top corner>usage and diagnostics >off this option.
11-10-2020 08:54 AM in
11-20-2020 12:53 PM in
Galaxy SDear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
