Battery Drainage
(Topic created on: 12-28-2018 01:36 PM)
Taha198
After the update of one ui , my s9+ seems to loose battery very fast. Please fix this issue
6 Comments
Not applicable
True, there is a lot under settings and users are confused! Is Adaptive Battery any good?
https://www.firstpost.com/tech/news-analysis/smartphones-running-on-android-pie-are-facing-drastic-battery-drain-issue-5491281.html
Mady0071
i m getting better battery life now..earlier maximum was 3.5Hrs now after 3 hrs also 46% left
Mady0071
Raheel
sucks
Ehm
very real. I have the same concern as well. I sent the error feedback to Samsung but I haven't receive any update yet. I hope they will fix this ASAP
Not applicable
https://www.sammobile.com/2018/12/28/final-galaxy-s9-pie-update-possible-battery-drain-issue/
