Battery Drainage s20 fe 5g
(Topic created on: 11-27-2021 01:14 PM)
A7G
My s20 fe 5g is 2 months old and I only get around 4-5 hours of sot, I can't figure out the issue.
Idle drain is also somewhat high.
Any help would be appreciated.
Here are gsam screenshot.
Mine is 4g version
Getting 6 to 7 hr sot
Even more if I don't gaming.
A7G
🥺 what is your refresh rate?
Mostly using 60hz.
One more thing I've turned off all vibration(haptics) in every application 😂.
Always dark mode. Amoled wallpaper and lock screen.
Not using any assistant 😆.
A7G
**bleep**, I don't like to use phone without haptics, it feels nice, also, I like using some assistant, google or bixby
Exception me😂.
I don't like this feature at all.😆
Yes I do use assistant but on my other device.
iamrohitkm
I think 4-5 hrs SOT is decent only for the battery. Don worry too much and use all the features in the phone.
A7G
Thanks man. I was confused if I got bad battery or something
Vijay93452
I used to get more than 6 hours of SOT in my LG G8x with 4000mah battery.But S20 FE 5G with 4500mah battery i am getting 5 to 6 hours only
iamrohitkm
I understand but Samsung has high quality display which consumes so much battery so it's normal. Don't compare with LG.
