11-07-2020 06:31 PM in
Galaxy S- Mark as New
11-07-2020 06:37 PM in
Galaxy Sbut anyway i would like to suggest you some battery settings if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Connection>more connections settings> disable nearby device settings.
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Google >click on 3dot at right top corner>usage and diagnostics >off this option.
11-07-2020 06:55 PM in
Galaxy SBut I shouldn't be required to do these adjustments as it is a brand new phone 😕
11-07-2020 07:03 PM in
11-07-2020 07:40 PM in
11-07-2020 08:07 PM in
Galaxy Sbut anyway its your choice
11-07-2020 08:15 PM in
11-07-2020 08:20 PM (Last edited 11-07-2020 08:21 PM ) in
Galaxy Snew updates always coming with some pros and cons.
now a days update is removing features more than giving new one
but hope for the best
11-09-2020 01:41 PM in
Galaxy SHello Bro, i am also using s10 lite that i have bought last month, i am telling you my phone's battery life so you can have an idea about your ohone too, i charged my phone at morning(10-11AM) about 90-95% and i am using mostly youtube, whatsapp, instagram, and chrome for news feed these are the main application which i am using the most, and it will decrease down to 30% at 8-9PM yes i am taking 3hours calls also, so keep in mind that also, i estimated that if you charge 100% and take down to 5% the average SOT(Screen ON Time) will 9hours according to my usage, if your playing games and using heavy application then it will vary.
11-09-2020 03:56 PM in
Galaxy SI think I might be getting similar backup.
I am assured that my battery isn't faulty:)
