Battery Drain
(Topic created on: 12-26-2025 03:49 PM)
muqa
I'm experiencing battery drain after the latest update. Please help.
4 Comments
Andreisamsung
May i know what phone you are using
muqa
S23plus
After updating, some settings need adjusting. Try searching on YouTube; you will find a solution.🤝
Samsung_specialist
Thank you for your inquiry on the Samsung community.
If you're experiencing battery drain after the latest update, please follow these steps to help improve battery life:
  1. Check Battery Usage: Go to Settings → Battery and Device Care → Battery to see which apps are consuming the most battery. If you find any app consuming unusually high power, try limiting its usage or reinstalling it.
  2. Disable Power-Hungry Features: Turn off features like Wi-Fi, Bluetooth, or Location Services when not in use. You can also enable Power Saving Mode from Settings → Battery and Device Care → Battery → Power Saving.
  3. Clear Cache: Go to Settings → Storage → Clean Now to remove any unnecessary files that might be affecting performance.
  4. Background Apps: Make sure no apps are running in the background unnecessarily. Close apps you don’t need.
  5. Check for Updates: Ensure that your device has the latest software and app updates, which might include improvements to battery performance.
If the issue continues after following these steps, we recommend visiting your nearest Samsung service center for further assistance. You can find the nearest service center through the link below:
Samsung Service Centers
