Highlighted
Has anyone observed that S10 battery drains too quickly after recent OneUI update or is it just for me.
10 Comments
Highlighted
me too feel that it drains fast
Highlighted
guys please advice if this is normal or is the drain really draining like crazy
Highlighted
Get the new update
Highlighted
I don't know man.I believe it was comparatively better before the update.I used to get more than a day.now it is just 14 15 hrs .
Highlighted
guys try to modify the screen brigthness & resolution depend on your current usage if for gaming or texting or the standard mode
Highlighted
Check Device Manager and look for apps that are running in the background. Put apps that you don't need to sleep and leave only essential apps in the background. Samsung's battery management is poor when compared to Oppo, Xiaomi or the iPhone. My 3 year old iPhone 7 Plus is much better than Note 9 albeit having a bigger battery than the iPhone
Highlighted
turned off the always on display and tweaked the phone especially when am sleeping with the moderate power saving feature i get around 28 hrs of battery time currently.
Highlighted
Hmm seems like amazon prime is consuming a lot of battery .Thank you guys for the replies
Highlighted
samsung could never deal with battery
always it drains fast
still we fools are buying this crap
