Battery Drain
(Topic created on: 04-30-2025 09:13 PM)
PSYRIS
I am experiencing significant battery drain on my Galaxy S23 after updating to One UI 7. The battery life has noticeably decreased even with minimal usage, and the phone heats up occasionally. I have tried restarting the device and checking battery usage, but the issue persists.
Please advise on any known fixes or whether a patch is expected soon.
2 Comments
I have the same issue with my S23 Ultra after installing the update and if you focused you will find that the charging speed become slower( when using wire charger with fast charging off), also the RAM usage has been increased (before the update the RAM usage was between 4.** GB to 5.** GB, now it's from 6.8 GB to 7.6 GB most of time)
Also the location service icon appears on the notifications area near the battery icon almost every 4 or 5 minutes and every time I use any app.
shabee33
I have also
