Resolved! Solved
Battery Drain
(Topic created on: 08-08-2023 01:47 PM)
imbu
Beginner Level 3
After the latest update on my S 22 Ultra i I am going through severe battery draining issue. It's happening when phone is in standby/sleeping. Anyone having the same issue?
VikrantTambade
Hi,
It is recommended to wipe your cache partition through recovery mode after update. It should solve your problem.
3 Comments
VikrantTambade
Hi,
YazanMaklad
OH NO!!! WHAT HAPPENED, IMBU?
Samsung_specialist
Hello,
Kindly make sure to use the original charger, you should go to the settings > battery and device care > optimize now. Otherwise, you should visit the service center.
