Battery Drain on S25 ultra
(Topic created on: 08-07-2025 12:00 PM)
EnochMk
For the past three weeks now the battery life on my S25 ultra has been slowing getting worse and I don't know why, I tried wiping my cache but still nothing seems to work
4 Comments
Princessbite
Try battery saving mode. That might help. The weather also makes a difference in how long the battery lasts.
EnochMk
Yeah it does help but I usually don't use it often but I'll try thank you
innocent99
Try to turn on adaptive battery in settings and adaptive brightness...turn off unnecessary gestures and put screen resolution on default
EnochMk
Adaptive battery is always on, it's just the screen res that's set to quad HD, I do set to Full HD here and there but not often
