Battery Drain is a serious issue!
(Topic created on: yesterday)
VikalpM
Post update to one UI 7 i lost almost 20% battery backup. Earlier i used to run my phone for a full day now it only lasts 20 hours or so with moderate use.
Samsung users, if you haven't got one ui7 update, don't go for it. Else say goodbye to good battery backup.
Very very disappointed by Samsung and their updates. If you can't make quality of life better then surely don't make it worse.
8 Comments
Evzz
What to do then. Even i am facing the same issue
VikalpM
Cant do anything unless they release a patch to patch things up. Just infuriating.
Make sure you report battery issue in this app. More the reports, quicker the response.
VikalpM
Won't accept this as a solution because it isn't solving my issue which is battery drain post update. And waiting for something which you never know is not a solution.
Umesh07
Factory reset or catch partition clear data
VikalpM
Didn't update my phone to just Factory reset and loose data. If samsung can't churn out proper updates, what's the point in promising 7 yrs of software update.
Also deleting cache partition does nothing.
neodexter
Indeed, there is a rapid drain of battery 🔋 in the S24U post-update of One UI 7.0. This needs to be plugged by @samsung ASAP.
jayu2009
The May security update is expected to be 600mb to 900mb as it will solve the battery drain issue in S24 series and other series also
VikalpM
I already complete the may security patch which was 450mb approx. Did nothing soo far
