Battery Drain after Jan Update S20 fe 5g.
(Topic created on: 02-04-2023 11:08 PM)
antusouvik
Anyone facing this issue???
17 Comments
Axhwix
Sir just check the apps which were running in the background and if its ruining in the background the Clear all of them
帕里克
Yes
antusouvik
plz report
帕里克
Yes i did
帕里克
Samsung will not listen until mass complained. There is stereo type answer " reset". This is not only samsung brand but all brands doing it after sales. Their moto is "do not listen to customer ".
antusouvik
reply after attaching a screenshot of battery usages Screenshot_20230206_150119_Samsung Members_1000032805_1675675879.jpg
RAML
Network problem
sukhjinders
Yes I noticed charge my device 3times a day after Jan update before 1 time only or max use 2 times
antusouvik
plz report
