Battery Drain Issue
(Topic created on: 01-15-2026 09:50 AM)
KishanBiswas7
My galaxy s23 ultra is giving only 4 hours of screen on time without any gaming sessions,
Just the social media scrolling giving me 4 hours of SOT.
Please give me some suggestions what should I do @samsung
3 Comments
praveenrajn
Instagram will eat your battery. Stop using Instagram and scroll YouTube and see the difference it will double
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select "try another way" > Next > Enter a new password > Next.
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
RICCMMAN
Live with it
