Battery Drain Issue
(Topic created on: 05-27-2023 11:36 PM)
Devjit619
Is this normal ? I am using Samsung galaxy s20 FE 5G. Battery dropped 10% with only 12 min sot.
Is anyone facing the same issue ?
My phone was on 5g network.
11 Comments
pramodn85
From my experience it seems Samsung needs to fix this draining issue on all of their models. One UI is the main culprit due to the optimization issue. They just rolling out updates without any propers testing. Just to showoff other brands that we are number 1, but they don't realise that we the fools who buys phone of their so called FLAGSHIP models are having this battery drain issues and even lagginess. So sorry to say that Samsung is now the worst brand....
Turn off 5G and check if the battery drains at same rate.
Devjit619
Yes, I am doing that now.
Im also S20 FE 5G user I think my device battery life is good and its quite decent on 5g network.
Devjit619
Can you please share your battery usage so that I can get an idea ?
Definitely brother tomorrow I will share you.
Here I'm sharing my normal usage of device.Screenshot_20230601_221715_Device care.jpg
piyussh07
Bro, battery stats updated nhi hai hai. Around 20 minutes lgte hai update mein, phle 20 minutes se 12 minutes sot dikha, 10 minutes baad dekha hota to update hokar yeh thoda aur increase hona tha.
Baki iske alawa bhi, yeh normal nhi hai.
Merepas s21fe hai, ese sot ke probable reasons -
1. Because Screen off time kaafi tha phle to uske baad jese phone chlaya to battery drop jldi hoti hai (kaafi baar hua hai mere sath)
2. Apps open the bg mein, plus YT music bhi play horha tha bg mein, to itni battery drop hona normal hai. Next time yt music ko open krna jab esa sot stats dikhega, screen off time se smj aajayega.
Aur agar music play nhi krre the to normal nhi hai esa drop.
Fixes -
1. Add apps to deep sleep
2. Perform Galaxy App booster from Good Guardians
3. Make routines
if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
FOR ANDROID 11;
A. DEVICE CARE > Battery>Background Uses Limit > Put Unused App to Sleep
B. Device care>click on 3dot at top right corner>automation>adaptive power saving
C. Device Care > Battery> More Battery Settings>Adaptive Battery
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info(ibutton)>> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> Manage account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on weather settings (icon)> change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
(Ehsank)
