Resolved! Solved
Battery Drain Issue in Samsung Galaxy S24
(Topic created on: 3 weeks ago)
Ungal_Nk
After the Recent September Update for 2.8GB there was a battery draining issue. My phone is getting drained little quickly compare to previous updated. They have given extra features in this update but they need to concentrate on Battery Optimization.
Anyone facing the same issue?.
2 Solutions
JoKeR_77377
You can use the above link for reference and link to apps. Please accept this as a solution via 3 dots on the message if it works for you. 😊
goodthings
24 Comments
JoKeR_77377
Download good guardian and run optimization and restart the device once.
Ungal_Nk
Thank you
Ungal_Nk
Tried it bro. It's not working. Not able to download the modules
JoKeR_77377
Download the apk installer and then try it should work. 1st install the guardian app followed by the other files.1726073317818_1726073317809_0.jpg
Ungal_Nk
Ok bri
JoKeR_77377
https://drive.google.com/drive/folders/10Bwj3n22NW_Ytk2UJO93UStkftkCLfAh
Try this link download the guardian app 1st and then the other files 1 by 1
JoKeR_77377
SachinDnl
Wait for 4-5 days cuz after update battery drains fast is normal bro
