Hari14
02-03-2017 04:24 PM in
what are all the possible ways to conserve battery in S7 edge after nougat update any suggestions ?
its been reducing like 10%-15% per hour with wifi on and some minutes of gaming ! Is that okay ?
2 Comments
mickias
02-07-2017 08:34 PM in
it is not ok. but it depends the way u updated ur phone to nougat. I did OTA and it has minor bugs because the cache of the previous marshmellow 6.0 is not fully cleared and also keep in mind that we are on January security patch and no major update rolled out since. but if you updated to nougat by resetting your phone or did a factory reset. you should be fine. overall all I am experincing is minor lags. but as you said if ur battery drains fast you should clear the cache and try it. if not do a reset, and if reset doesn't fix ur problem send it to Samsung if your warranty is still valid.
Hari14
02-09-2017 06:57 PM in
I cleared my system cache and then only i updated nougat ! tanks for u suggestion will look into that .
