09-02-2024 01:13 PM (Last edited 09-02-2024 01:37 PM ) in
Galaxy SSolved! Go to Solution.
3 Solutions
09-02-2024 01:49 PM in
Galaxy S- Mark as New
09-03-2024 08:09 AM in
Galaxy SDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links. However, we are taking your valuable feedback regarding this.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
09-02-2024 01:52 PM (Last edited 09-02-2024 01:52 PM ) in
09-02-2024 01:53 PM in
09-02-2024 01:52 PM in
