โ˜…
According to the latest rumors, The guys at GalaxyClub have now uncovered a photograph of a Samsung battery carrying model number EB-BG988ABY from the SafetyKoreacertification database.
It is clear this battery will be part of the SM-G988, better known as the Galaxy S11+. The image leaves little room for guessing, as we can clearly read the battery will have a typical capacity of 5,000 mAh, and a rated capacity of 4,855 mAh. If you previously fantasized about a Galaxy flagship with the battery of the Galaxy M20, your dream will come true in 2020.
Galaxy S11+ will desperately need power in such quantities. After all, it is expected to pack a whopping 6.9-inch displaywith a 120Hz refresh rate
Still, you can always choose to use the device at a measly 60Hz refresh rate and actually enjoy the benefits of having a 5,000 mAh battery capacity.
Finally a flagship phone with Flagship level Battery...wowwโœŒโœŒ๐Ÿ‘Œ
3 Comments
Manojtomer
Good
shinchannohara1994
haan tv wala phone ban raha hai toh battery bhi tv wala hi lagne wala ๐Ÿ˜‚๐Ÿ˜‚๐Ÿ˜‚ 6.4 6.7 6.9, kuch din baad note 11 mein 9.0 screen usme bhi tv wala battery ๐Ÿ˜‚๐Ÿ˜‚
SamratGhose
๐Ÿคฃ๐Ÿ˜‚
