Anyone facing issue with wired Android Auto ? Especially Skoda cars
(Topic created on: 01-22-2025 05:35 PM)
TimonN
Hello,
I should have posted this earlier. But today after checking my skoda kushaq with skoda service team, I found that Android Auto via Cable(wired) doesn't work with my S23.
But with other Android phones like OnePlus it works.
Any one facing similar issue ?
Note: Android Auto works wirelessly. This issue is only when I try via wired method.
Best Regards
8 Comments
I have Nissan Platinum. Works for me.
Ok , Android Auto works via both methods - wired and wireless ?
ojwh
Hi. Was it working before or is it a new phone?
It has never worked. I took to service center and their they showed that it was working with other Android phones. But with all Samsung phones , I tried it failed.
ojwh
Hi. Ok. Quite unusual. I've never heard of this issue before. I did a quick search online and saw that some people have mentioned issues like this, with other brands of phones & cars.
Did you ask your services guys if there's a pending software update for the car? Maybe at your next service?
My only suggestion is to try working through a process of elimination to identify what the Issue could be.
Try temporarily disabling Auto Blocker and then connecting via USB to see if anything changes. Don't forget to re-enable it after you're done. Please let us know.
Actually I guess I have tried all which I could think of.
- Asked Skoda service to update SW which they said was already updated.
- Auto Blocker is disabled.
- Tried different cables
- Reset Car navigation system
- Reset Phone
- Tried different phones
Now since I have used my phone with android auto wired on my Suzuki Ertiga back in India , I feel faulty combination is Skoda Kushaq system + Samsung
As with same Skoda Kushaq , OnePlus , Vivo phones with without issues.
The old Nissan needs a wire.
Ok
