05-18-2024 09:45 PM in
Galaxy S- « Previous
- Next »
05-19-2024 05:37 PM in
Galaxy S- Mark as New
05-18-2024 10:26 PM in
05-18-2024 10:28 PM in
05-18-2024 10:49 PM in
05-18-2024 10:50 PM (Last edited 05-18-2024 10:50 PM ) in
05-18-2024 10:55 PM (Last edited 05-18-2024 10:55 PM ) in
05-18-2024 10:51 PM (Last edited 05-18-2024 10:51 PM ) in
05-19-2024 11:36 AM in
Galaxy SDear Samsung Member,
As per your concern, we want to inform you that the software update is developed to enhance the performance or stability of the smartphone and it is fully tested in different stages. The issue could occur due to usage and various other factors, in case there is any kind of issue that occurs after the update then we are always helping our customers to resolve their issues. However, Kindly perform the following steps to resolve your issue by using the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
06-06-2024 11:22 PM in
06-16-2024 11:28 PM in
- Next »
