Any battery draining issues after Nov Dec update for s23 ultra?
(Topic created on: 12-21-2024 11:29 AM)
maramkotthhi
10 Comments
Didionpc
Yes, there have been reports of battery draining issues after the November and December updates for the Samsung Galaxy S23 Ultra. Some users have noticed a faster battery drain following these updates.
If you're experiencing this issue, here are a few steps you can try to improve battery life:
Reduce Screen Brightness: Lower the screen brightness or use auto-brightness mode.
Turn Off Unnecessary Services: Disable Bluetooth, Wi-Fi, or GPS when not in use.
Close Background Apps: Ensure that apps running in the background are closed.
Update Software: Make sure your device is running the latest software version.
Disable Power-Hungry Apps: Identify and disable or uninstall apps that consume a lot of power.
Clear Cache and Data: Clear the cache and data of problematic apps.
Check for Malware: Ensure your device is free from malware.
If these steps don't help, it might be worth contacting Samsung support for further assistance. They can provide more specific troubleshooting steps for your device.
If your question has been answered, please press the "Accept as Solution". You will find in three dots to the right of my comment.
maramkotthhi
Am already contacted with samsung but no benefits they where saying only basic settings that already am installed...
Didionpc
Maybe they note the issue and fix it in any patch or new update. Let us wait and see.
maramkotthhi
Thanku for your confirmation
Didionpc
Samsung_specialist
Hello, we understand how frustrating it is when your battery drains fast. To address the battery drain concern, we recommend performing additional troubleshooting steps to identify the root cause of the issue. These steps may include:
1. Update Software: Ensure that your device's software and related apps are updated to the latest version. To update your mobile device's software, follow these steps:
   - Step 1: Go to Settings > Software update.
   - Step 2: Tap on Download and install.
   - Step 3: Follow the on-screen instructions.
2. Setup Phase: Your new phone’s battery may initially drain faster as you set up applications and features. This is part of the setup phase, and background operations are optimized during this time. Allow a few days for all background operations and syncing to complete.
3. 5G Service Impact: While connected to a 5G network, your phone may consume more battery than usual due to the high-speed processing of large-capacity data. Consider optimizing overall usage and adjusting background usage limits.
4. Optimization Steps:
   - Open Settings > Battery and device care > Optimize now.
   - Adjust Background usage limits: Settings > Battery and device care > Battery > Background usage limits.
5.  Use adaptive battery: Settings > Battery and device care > More battery settings > Adaptive battery.
maramkotthhi
Already done these all steps..
maramkotthhi
Pls rply
kogfgg
ت
