Adaptive Power Saving Mode
(Topic created on: 11-25-2021 02:39 AM)
Not applicable
Hello All ...
How does "Adaptive Power Saving Mode" under "Automation" in "Device Care" work ? It says it automatically turns Power Saving Mode - ON & OFF.
However in my experience of 4-5 days since I have had the device, I have only seen it turn the Power Saving Mode ON.
Despite using the phone actively and the battery levels being above 60 or 70% it doesn't turn it OFF automatically unless I do it manually. And when I turn off Power Save Mode manually, the Adaptive Power Save under Automation gets disabled. I know I can manually turn Power Saving Mode on as well, but I'll rather like it to be done automatically and save some battery while my phone is idle. But I'm unable to figure out how does this thing automatically deactivates the Power Saving Mode.
Anyone has any suggestions / experience to share ?
Device - S20 FE 5G
One UI Version - 3.1
7 Comments
Prabh-preet
Bro it turns on off automatically
When will u plug in charger it will automatically turn off and after charging depending on ur usage phone will turn it on by self
ACCEPT AS A SOLUTION IF U FOUND HELPFUL BY CLICKING ON 3 DOTS
Not applicable
In my case it turns on automatically but then never turns off unless it's reconnected to the charger. I'm unable to understand what patterns is it learning because I wouldn't expect the Power Saving Mode to be automatically remaining on while my battery is above 70% and I'm actively using the phone.
Prabh-preet
Bro then use it for a month and try if it turns off and on automatically
In my case when i start using my phone if my battery usage is high it automatically turns off and when im using apps like whatsapp,insta etc. It doesn't turn off because of low power consumption
Not applicable
Let's see. Yesterday it started automatically when battery level was like 77% and stayed on till I plugged it to charger at night at about 15% battery left. Very strange. Continuous Power Saving Mode from 77% to 15% is actually annoying because I end up using a phone at 60 Hz instead of 120 Hz. At some instances it's okay to save power. But from 12pm till 1:30am in Power Saving Mode is not fun. Samsung's prediction on when the Power Saving Mode is needed is very poor.
cs-member13
Expert Level 4
Dear Samsung Member,
We acknowledge your query and apologize for the same. Please visit this mentioned link to resolve your device issue: https://www.samsung.com/us/support/answer/ANS00079037/#:~:text=First%2C%20navigate%20to%20Settings%2....
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Is there any update on this ? Because I have the same issue
fidorulz
Im curious about this feature as well because I would like to use power saving mode ONLY to reduce the CPU to 70% but issue is with power saving mode on many apps including the calendar do not sync in the background which is something I need my phone to do
