Highlighted
After update my phone battery drain rapidly.Before Update my phone battery life is almost 8 to 9 hours with normal usage.After receiving One UI 2.0 update its reduced(its 6.5 to 7 hours).I have charge my phone 100% at night and unplugged it and i jave notice that my battery is 70% or 75%.There is no background app running.
So what should i do to increase my phone battery backup.
2 Comments
Highlighted
I think it is a big.
Best switch off mobile during night until new patch releases.
Highlighted
check for apps using more battery life in background and disable or uninstall them ....Reset it once, if battery drain continues show it to Samsung store . battery kit costs around 2.5 k
