A serious problem.
(Topic created on: 07-09-2018 07:19 AM)
Salameh1
I was using my s8+ with Always On Display on and keep it on all the time, but when i wake up i find my mobile phone dead 0%, i tried to sleep with AoD off when i woke up it was just the same percentage that i left before sleep, i hope sam find a way to fix this.
note: I'm using only the black and white clock.
6 Comments
syedarif88
try with a different AOD and check
Salameh1
i did, noticed just the same.
Striker247
See what other apps are using your battery it could definitely be another app such as "google play services". Just go to your power settings
Salameh1
unfortunately i put all the apps into sleep mode, nothing is working in the background, even when i turn the AoD off the percentage when i wake up is just the same which i left before slepp, but when i turn AoD on i wake up and the mobile phone is dead.
khan19121s
you need to go into the settings and then apps and go to always on display,storage and clear cache,and clear data also then,press 3 dot's present overthere and then click .show system apps.then back,and click again 3 dot's and reset apps frequency shown there when you reset apps frequency you need to restart your phone and see whats happened then i think may help you thanks...
Alham
I can not save contack
