A Custom OS Can cause critical problem on startup.
(Topic created on: 11-24-2016 11:25 PM)
mohsin1234
when i restart my s7 edge there is a note show on startup " custom os can cause critical problem press volume keys to cancel and install" please answer
4 Comments
JB0071
that's correct. don't do it. you are entering download mode. to exit press all the buttons at once to exit download mode.
mycota
what happens if you do it?😕
JB0071
nothing if you only enter download mode. but if you flash a custom firmware you will trip Knox. no more warranty, no more samsung pay, etc just like if you were to root the phone.
admin_1
This is normal operation if device is rebooted by pressing the VOL down key + Home + Power button.
