AthulHackz
08-06-2020 08:22 PM in
Galaxy Note
Hi guys,
Can you guys please inform how much screen time do you get once you charge your note 10 plus to the 100%? Mine is like max 4 hours peak.😶
#samsungmembers#galaxy#note10plus
6 Comments
RabieM
08-06-2020 10:15 PM in
Galaxy Note
charging your note10+ in 4 hours to reach 100% ?
AthulHackz
08-07-2020 12:25 AM in
Galaxy Note
nopez..for charging it takes 1 hour only but its draining too fast!!
mas921
08-07-2020 11:14 AM (Last edited 08-07-2020 11:16 AM ) in
Galaxy Note
8.5-9 hours if medium power save mode is on, 7-7.5hours SOT if max/optimzed is on.
mine is a UAE variant exynos (n975f) that I got at launch, so battery is 1 years old already.
this is how I get this:
I used AccuBattery to look for battery draining apps and disabled them in background.
I dont have anything I don't use turned on (stuff like NFC, air actions are off, Bluetooth is off, but use near by scanning for galaxy buds ...etc) GPS is on though all the time for the local covid19 tracker app here in Bahrain.
also my carrier have very good signal where I live and work, so phone doesn't need to consume lots of power grasping for signal.
TL;DR: Just get AccuBattery and check for apps that drain the battery ;)
AthulHackz
08-07-2020 11:17 AM in
Galaxy Note
thanks for the info!!!
balukb
Beginner Level 5
08-09-2020 08:21 AM in
Galaxy Note
athul..malayali ano...enik 5hr kitunund...heavy gamer
AthulHackz
08-09-2020 08:26 AM in
Galaxy Note
athe...game angane kàlikkarilla...ennalum standby time ilum charge drain akunund..
