problem with samsung Note 10 plus display discoloration.
(Topic created on: 09-24-2020 09:12 PM)
bis19
Galaxy Note
When I reduce brightness their is yellow and black vertical  lines on my Display..but if I increase  my display brightness into maximum then..all lines and yellow line disappear..
Any body is facing the same problem pls..reply
19 Comments
vimaleshbe
Galaxy Note
Same issue happening for me in note 10 plus..
@bis19 how did you resolved this issue
bis19
Galaxy Note
Vimaleshbe bro..still it exists..I download 1 software..nw my work is going on..but screen resolution...is not same as earlier...as I m out of india nt able to go to service center ...bro
bis19
Galaxy Note
Vimaleshbe did u visit any samsung customer care????
ChandanSaxena
Galaxy Note
My note 10 plus ,same problem
anyone please help ?IMG_20210708_095643_4653.jpgIMG_20210708_095802_4643.jpgIMG_20210708_095717_4647.jpg
bis19
Galaxy Note
I hv same problem since last September...
ChandanSaxena
Galaxy Note
If this problem not fix i'll never be a samsung fan & will not use any samsung products it's my promise to samsung.
Samsung_DXEcC8M
Galaxy Note
I do have same issue. Any solution?
rupon23
Galaxy Note
You problem was fixed yet?
ChandanSaxena
Galaxy Note
Yes , solution is to replace smartphone with apple
Samsung's Screen burn in can't be fixed if you have too much money then buy new note 10 plus or note 20 ultra wait for screen burn in then again buy note 20 ultra or note 10 plus & make sure to transfer all data to new phone 🤭
i'll never ever buy samsung going with apple✌ i know it's expensive but my friends iphone xs is far better than my note 10 plus.
Santosh22333
Galaxy Note
I am using Samsung Note 10 plus from last one year facing the same issue, I two devices both are having same issues
Is there any Solution?
