one UI 2.1 drain battery so fast and heating up phone.
(Topic created on: 04-08-2020 04:34 PM)
sapmarvins
Galaxy Note
The one UI 2.1 is draining my galaxy note 10 plus battery so fast and causing the phone to heat up as well. Is anyone having the same problem?
16 Comments
shriansh
Galaxy Note
I am having the same problem with my galaxy s10 after one ui 2.1 update
Talhailyas
Beginner Level 3
Galaxy Note
I'm having same problem After OneUI 2.1 on my Galaxy A51
sapmarvins
Galaxy Note
If you try to restart your phone and you still have the same battery drain. Try to open the battery usage section and see which apps is draining the battery. Click on the app put it to sleep imelmediately when not in use or still put it to deep sleep. Let me know if this fix the battery drain issue
Jeffh
Galaxy Note
But now can't put samsung keyboard to sleep
sapmarvins
Galaxy Note
Jeffh
Galaxy Note
Same here with a10s, draining battery overnight by itself,, this started after updating Android is 9 to 10 and one ui 2.1
Amin78
Galaxy Note
Hello, same problem for me after updating to One UI 2.1 on Galaxy Note9, battery drain and heating up. No problem before with One UI 2.0. Restarting did not resolve it.
