Highlighted
abdul001
hi every one. I want to share my experience after updating my note 8 to oreo. I am facing some issues like WhatsApp application crashes very frequently but my main concern is battery timing after oreo update my note8 battery just drains very quickly like more then 30% within 2 hours with just normal mobile usage. no Facebook and YouTube. only WhatsApp.
any other note8 user experience the same issue ?
12 Comments
Highlighted
Craigdylan
Hi have noticed the same battery drain after the recent update. During my previous usage, I would go about 65% by night time but now I'm reaching for the charger by 6pm. I'm not a heavy user so I know that something was off with the latest update.
Highlighted
RoyalMughal
Go for hard reset (factory default) and try, hope it will solve the problem.
Highlighted
abdul001
I will try that.. hope it will work for me.
Highlighted
RoyalMughal
Don't restore backup, setup as new device after reset.
Highlighted
abdul001
ok. my device heats up too while charging. this was not the issue before oreo.
Highlighted
allol
me the same
Highlighted
abdul001
have you tried hard reset on your device?
Highlighted
RoyalMughal
Go to battery, advanced setting and switch off fast cable charging and see the difference.
Highlighted
abdul001
Already disabled it. now my phones battery is working normal like it was before. I didn't hard reset my phone,. don't know how it fixed. strange but glad it is working fine now.
