my note8 battery issue
(Topic created on: 06-18-2018 09:41 AM)
mitulbhoot
Galaxy Note
since last 2 weeks my note8 battery drains drastically fast. always on display is off during night.if it is at 100-98 %at 23.30night , in the morning 6.30a.m.,it is only 80-85%. in standby how much it should drain?
initially it was only less by 2% of whatever at night.
how to solve it?
8 Comments
sawan07
Galaxy Note
yeah same problem with mine too.
Can't find out the solution bro.
We need an update by manufacturer to solve the problem
Shaileshm
Galaxy Note
Bro same problem my note 8 AFTER update
admin_
Galaxy Note
Thank you for Joining Samsung community. We would recommend you to follow some troubleshooting steps in order to further isolate what you may be experiencing in your device. Find the troubleshooting steps on the provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let us know what steps you have taken and if you have noticed any changes or improvements as this will help the Community to provide you further troubleshooting steps without repeating any procedure which you may have already followed. Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
Ntinykumar
Galaxy Note
Few days back I purchased it , After orieo update, Battery sucks 1% in every minute. Phone not works more than 10 hous, However I am able to manage 4 hours screen on time when I disable bixy, Less brightness, All application under sleep mode, All notification stopped. But this tips and tricks are not they actual way, we should able to use all facility and best battery life as we paid higher for samsung mobiles. Chines phones are good after keeping everything on like GPS , full brightness, sync, , notification etc. they runs whole days without any issues and their phone having the same battery size like Note 8
mitulbhoot
Galaxy Note
troubleshooting link is not available. Talked to Samsung support and their executive try to understand and solve the problem via smart tuter. Also I have followed the steps :-
1) 150 min.normal charging in switch off condition.
2) uninstall latest application that I have installed.
3). In last factory reset. but still the problem is as always. I think This problem arise after 1jun2018 update.
please Samsung solve it. in standby mode battery decrease by 15-20% in 7-8 hours. and with always on display off.
Ntinykumar
Galaxy Note
mitulbhoot
Galaxy Note
these steps are suggested by Samsung customer care executive
mitulbhoot
Galaxy Note
issue solved by July 2018 update. now no such issue of battery drain.
